I have read up alot already and heres what I found. I replaced the head and some other parts. I have it back together and running.
Heres the problem. I beleave the chains (2) skipped a tooth in the bottom sprocket. Timing is WAY OUT about a 1/4 of the crank pulley BTDC.
The question is is there a way to fix other than pulling the head and timing cover to and resetting he whle timing.. the motor is a 22r with weber carb.
