Help - Right Hand tail light wiring
CT
I had a few wires break on the right hand tail light. Now they are all seperated.
The "red" light - black & red wire and a green & white wire and the ground wire
The amber light - green & yellow wire and the ground wire.
I assumed that like colored wires would be connected to like colors. That did not work well.
The wires from the wiring harness:
Black/white with red marks
Green/yellow
green with red marks
green/white with red marks
So, what gets spliced to what?
The wiring diagram I've looked at leave me lost.
Any help is appreciated.
@jmylie You can throw your frame number into:
And from there confirm that this is correct - I believe 81555-60390 might be the part number for that connector harness.
Here is an Ebay ad from PartSouq for this part:
You can use the pictures of the non-broken harness to compare, if that helps. Just swap whatever part number you find after inputing your frame number into ToyoDIY if the above is not correct. I just guessed based off your signature to use a 1991 LJ77.
Electrical > Rear Combination Lamp > "SOCKET & WIRE SUB-ASSY, REAR COMBINATION LAMP, RH".
Keep in mind there was a substitution for the above part number:
81555-60390 > 81555-60391
Otherwise, the electrical wiring diagram would be explicitly helpful if you can understand how to read it. Don't blame you for being discouraged from that though :)
They say a picture is wortha thousand words
I pulled the drivers side and followed the colors. I was left with 2 wires and assume they are for the trailer hitch.
Lights are working, so we are good to go.
I'm glad you fixed it, but admittedly I provided a different type of tail light harness... Didn't know it was the bumper-style, but I guess the wiring is the same or similar.
Some day I plan to get the "regular" tail lights wired in.
