Help, Removing radiator on 93 FZJ80!!!!
Clearwater, FL
Hi,
Need some help and suggestions on how to remove two front bolts that are just behind the condensor. Seems that I can't find a way to place either a socket, even with an extension or 10mm wrench in order to remove them.
What are my best options?????
Thanks,
Alex
85 BJ70
93 FZJ80
Help removing radiator, problem explanation correction
I am trying to remove support collar insulators and the A/C condensor is right on the way removing two nuts.
Thanks,
Alex
85 BJ70
93 FZJ80
Remove the bolts that fasten the condensor. Move condensor slightly aside. Radiator bolts are then accessable.
I was just doing this last night, Yes to move the condensor to the side, I had to move the condensor as well as a trany oil cooler. The bolt that was by the a/c dryer just kept spinning untill I relized it was taking to long and put vise grips on it. They are held fast with presure from the rubber bumpers I believe
Have fun
Steven
