Help Problem Solve-Brake Issue
I have a 99 and all is well with the rig. However, I get an intermittent ABS light on. I had the computer scanned and it stated I had a bad rear, left wheel speed sensor. Replaced it...
Still getting the light on intermittently...
I can literally drive 300 miles before the light will go on...
At times I can feel the brake pedal pulsate like an ABS situation but it is not...Then, the light will go on.
Here are some things I am going to check...Any other ideas? Thanks!
Bleeding the Brakes
Poor Connection for new Speed Sensor
Probably a different ABS sensor. Or maybe somewhere between that sensor and the ECU, that wire might be buggered up.
