2003 LC, 148k miles, OME 1.5' lift installed by previous owner including the notoriously stiff OME shocks.
Recently had my CV axles replaced with OEMs at my long time shop. They're not a Toyota or LC shop but I trust them and have done business there for many years. I like that they have a loaner fleet, I know everyone there by name, can drop by to ask questions without an appointment, walk into the shop and look at the vehicle being worked on etc., all things one can't really do at a busy urban dealership.
The replacement was done because the ones on the truck were cheap replacement parts which I had discovered after reading through service records, one boot had failed and there was a persistent rotational noise which has now gone away. All the suspension bolts and bushings were checked/tightened during the job.
Pretty much from the time I picked the truck up after the repair I thought I heard a new clunking sound when going over bumps - mostly sounding like it was coming from the driver's side - in the front end that didn't seem to have been there before. I drove it around for a week to be sure I was't imagining it as I am kind of hyper about noises like that.
Convinced I wasn't hallucinating the sound, I took it by my shop today and on a test drive they heard/felt it too and agreed it wasn't present previously. We put it up on the rack and noticed that when rocking both front wheels some play was apparent with slightly more on the passenger side, though this didn't generate any clunking. Of course it certainly could have when under load. We have no idea if this play was present prior to the axle replacement.
The tech said if it were a Subaru or Saab (which is what they mostly work on) he'd think it was a shock going bad, though there is no evidence of leakage. These shocks are not more than a few years old and the truck is not driven much on rough surfaces. He suggested we both do a little research and see what we could find, so here I am. They always stand behind their work so that's not an issue. The just want to get it right for me.
Does this sound familiar to anyone?
Is there a trick to the CV installation they might not have known about?
Why would it suddenly show up after the repair?
Anything I should suggest they look into?
Your thoughts and suggestions are most welcome, and thank you in advance.
dude myself (getting better), I can answer a couple of these.
