Replacing rear pads and adjusting park brake, downloaded FSM from techinfo site says 26NM torque (20 ft/lb) for the mounting bolts for the caliper, normal specs from Toyota standard bolt tension specs show the same bolt should be 59NM minimum for 5T grade.............something is not right.........anyone have a FSM with the bolt torque for the rear caliper saying something like 59 NM or above?
