Which controller did you end up going with and are you happy with it? Thanks.All done! Controller is installed, i wired it with a 10 amp fuse through the fuse block. I also have 10 feet of wire that will connect to the controller to the panel. Hooked it up the other day and it works! I did not put a volt meter on it to see what kind of voltage i'm getting, but will do that later when i have time and a nice sunny day.
I had that charge controller but it never put out >2A at any given time during the day. Now I have the Morningstar MPPT 15L and it put out ~5.43A at 12pm in AZ sun.
Any decent charge controller should be able to charge a battery that's lower voltage than the panel. Where MPPT is especially useful is when you have an array of panels in series-parallel combination.MPPT is the way to go... morningstar is making a great product, next to Schneider and Outback that is. the mppt will allow one to charge a battery of lower voltage that the array is capable of supplying, so a 32/48/60+volt panel can charge a 12 volt system...
I heard the new ARB's use traditional Danfoss-style compressors, while the the older ARB's and Engel's used solenoid-style "swing" compressors, which were known for their low startup draw. But I have no idea about overall power usage between the two. With the advances in materials in recent recent years I've no doubt that insulation is much better in new refrigs, so that may be the biggest advantage right there....I'll likely pick up an ARB this upcoming trip back since they are much more efficient while holding more beer
cheers,
george.
