My front heater pipe is leaking inside the firewall and dripping on my drivers foot. I found the leak but can't find a replacement pipe. Its not leaking in the engine bay where the rubber hose joins the pipe but inside between the hold done clamp and the firewall. Leak is big enough that at 5 psi it pisses a stream. Does anyone know where I can get this replacement pipe? It's a discontinued part at Toyota and I have not been able to find an after market pipe. I am pulling the heater core tonight and will get a better idea of exactly why its leaking. This was replaced 10 yrs ago with a new pipe so I am puzzled why its leaking. Depending on what I find tonight, my only option is to solder if its a hole or remove and run the rubber heater hose through the firewall to the o-ring union.
