When opening the driver's side kick plate and looking for the circuit opening relay on my 62 so I can pull it, crank the engine over, have it die, and depressurize the fuel system, I am confronted with something that looks absolutely nothing like the picture in the Haynes manual (FSM is on the way).
There are 3 round metal relays, none of which when pulled kill the engine, as well as two other square relays (one black, one brown), neither which are the right relay. (and the flasher relay for the lights is there too).
In fact, the relays are mounted from above facing down and not on the side facing out under the panel, which is how they are represented in the manual. I'm not sure if they were moved (doubt it) to make room for the ridiculous amount of hardware needed for the alarm, shock sensor, and dual glass breakage sensors that the dealer decided to install (which in spite of all the lights blinking on the power boxes appear not to work.)
Can anyone tell me which is circuit opening relay? I'd post a picture if I hadn't dropped my digital camera and broken it about 10 minutes ago.
Thanks.
Thanks.
