Years ago a pair of Hella Ralley 1000 lights were added up front. They worked great and I rally appreciated the help they gave me.
Recently one light went out and now the other.
The swiitch link is tied into the high beam circuit for th emain headlights.
Fusable link from battery is fine,
relay checks out with good continuity across the closed poles,
There is not power at the leads to the bulbs. No DC Volts.
One bulb, the first one to fail has no continuity across the leads. The other does register continutiy.
Now, does the absence of continuity across the bulb leads indicate a failed bulb that should be replaced?
It is hard to diagnose someone else's installation, but is it possible that a failed bulb would interupt power to the other bulb? Would a failed bulb cauase the relay to overheat and fail.
Any help or ideas short of converting back to coal oil lamps is appreciated.
