hopefully you fellas can pick up what i'm puttin down, long time ago i dropped in a hei distrib/ replacing the old points style. is there a voltage regulator still or no?does the hei have one built in? sometimes
the thing is dead won't start, but give it a jump and she'll fire up. checked for a draw, can't seem to find anything. is there a way to check if the alternator is charging, is it possible that it is not charging enough? can a meter be hooked up to battery terminal while removed to check voltage ? and what kinda #'s should be expected. long winded i know but hopefully someone can give some knowledge...thanx men
