Howdy all!
I have watched this site for so long and picked up on a lot of handy conversations so big thanks to the tech wizards who have contributed their experience.
Scenario.
2001 Fzj105 - 212k on the clock.
Dual fuel, bought from old couple who towed caravan.
33" tyres.
Tough life for transmission.
- Heavy up shift, very noticeable 2-3, 3-4 *HYDRAULIC thud/clunk
- Regularly drops heavily in to D or R
- Much MORE noticeable in low range.
- Idles relatively high on petrol.. Say 700-800rpm.
- 450rpm on gas
Checks..
- No binary engine codes.
- Shift solenoids all check out at 13 ohm.
- Kickdown set at 0.5mm gap.
- Read Haynes manual back to front.
- Trans fluid and filter swapped out.. Wasn't too bad to start with
Thoughts.
- Possible slop in shift solenoid causing pressure issue.
- Over stretched kickdown cable
- TPsensor? Test procedure I found is for 4 pin, mines 3 pin connection.
- Possible to set higher oil pressure to support towing?
- overly tightened throttle cable?
I'm now at the mercy of your experience with this. Any hints or tips will be greatly appreciated.
Scenario.
33" tyres.
- 450rpm on gas
Checks..
Thoughts.
