Heater problem finally solved (two years!)
Richmond, Virginia
Dear Mudders,
My heat (or lack thereof) has been driving me to the point of wanting to sell my 100. For two years or so I have been battling extremely cold air through the floor vents, in some instances AC in winter, and moderate heat from the top vents. I finally fixed it through a succession of maneuvers. Hopefully this list will help somebody else in this same quandary.
1. Install new thermostat under the hood. While swapping heater Ts, back flush both the front and rear heater cores. This should remove the likelihood of “plumbing” being your issue(s). Rear heat worked like a charm after this step.
2. Replace the sensor that reads cabin heat and insure its vacuum line and electrical are hooked up correctly. This is right behind that tiny grill just under ignition. Photo showing grill and new part ($20 ish).
3. Remove blower fan on passenger side under glove box and make sure it is refuse free and clean running. Access at front footwell is easy, three fasteners.
4. Unconnect and reconnect the electrical connector on the small HVAC servo motor in the passenger floorboard area too. This was critical to my problem, either the connection was bad OR I rebooted this servo in the process. See connector in photo. I did this several times to clean up the connection.
5. Here is the sneaky one. Once the servo motor is now working (by giving differing commands at the dash) observe the metal shaft that is supposed to open and close a flap in the heater box near the servo. This shaft (photo) has a flat section on it for a reason, BUT mine was simply spinning in place. I pried the connection arm (carefully) down to make it seat on the flattened shaft, sprayed dry lube around where shaft entered the heater box, and voila The Heater Box flap began to open and close with the operation of the servo motor. This was an exciting moment!
5. Move your attentions to the dash area above the driver’s footwell. If you look up in there, other arms and flaps exist that need dry lube to work as well. Piece by piece, bit by bit, I managed to get all my flaps working again.
My heat appears to be working now to factory spec and it simply stays set to AUTO and a desired temp and delivers as designed. If you have similar issues, I hope some or all of these steps help you. I couldn’t find any of this on this forum, so decided to share. Happy Holidays.
good to know. thank you.
Every winter I go through the "I'm selling the refrigerator" thought process. Time to go look at a few things.
I survived off of rear heat on high but it gets pretty hot and you have to pull over and stop to adjust.
If that lower servo motor or the little hvac computer is not toast, and your rear heat is hot, you should have a good shot at fixing yours.
Get the truck warmed up and feel the hoses leaving the Ts under the hood. The rear drops downward, the front heat are the supply and return that are straight out of the Ts and through the firewall. If these are pumping hot, follow my steps #2 on. You are welcome to ping me for guidance if you desire.
I am dealer averse and never had them read.
This is perfect timing! I have a new truck with mix door issues i think. Awesome info and pics. Thanks!
I have this issue as well i havent been able to look under there and find the servo have you had any luck?
Doi need to remove the nav pieces or just go from under the passenger side?
Edit: nevermind mine has a plastic piece covering it i jiggled the connection and mine is back alive so i think ill leave it for now.
Good to know. I havent been under there yet
hate to bring this back from the dead, but does anyone know the part number for the cabin sensor? thanks.
FINALLY FIXED! Well, the heater is now perfect. Wow, what a friggin difference in comfort. I found an indie shop and they drained my heater core and put a chemical in there and soaked it overnight (C.L.R.). Now I set the temp on the dash and it just works. All my steps above made slight improvements, this work was the final and ultimate step. They recommended I flush it again in 3 months, and then annually thereafter.
@ClassyJalopy, aren't you having a similar issue?
Thanks friend. It seems that my heat and mixing doors are working as intended. I simply have outside cold air seep in to passenger foot well when it's set to get fresh air.
Curiously enough the flow of cold air is directly proportional to the speed of the truck!
Last winter I found that the plastic cover on the ac condenser was letting large amounts of air through. Replacing the cover with new rubber gasket and cabin filter door fixed that issue.
How much does it run for? I’m gonna go by the shop Thursday to get this quoted.
Here are notes from my receipt “Checked engine temp with scanner (190 F). Suspect heater core issue. Flushed out core, let sit overnight with C.L.R. Flushed today and heat is extremely hot (143.5 F) at center vent. Foot setting is never as hot as center vent due to design, but hot there also.“ $100.00.
best $100.00 I have spent on this rig to date.
Can you give a bit more info on the repair that you did here? I suspect that I have the same issue, as my LX blows plenty hot around town, but tends to blow cold on the highway, especially with the recirculation set to outside air. Thanks in advance!!!
Check out more details and pictures in this thread: Cold air on Passenger Side Floor - Has anyone figured it out?
Basically I had a major cold air leak from the cabin filter cover. I replaced the cover, the rubber seal and the filter door and that took care of the big blow of cold air. I still have a slight seepage that I haven't been able to fix yet.
