I have a noise that sounds like a heat shield vibrating against the muffler. I can hear it when starting out around 1000 rpm up to 1500. Then when coasting back down it hits around 1250 rpm and stops around 800 or so. Sounds like the rear of the truck. Makes the noise in drive or neutral. I have had all tires off, been under checking every heat shield, tubing, etc. All zircs greased and all gear oil levels checked. Is it possible that a baffle in the muffler broke? It is driving me crazy.
