midknightc3
Couple questions relating to this, I'v read all the threads I can find on the subject as I am pretty sure I have a crack in the intake manifold, and a significant leak around the pushing for the butterfly valve in the heat riser. I'm running the Holley Sniper setup, so both leaks are causing issues. My questions are:
How many bananas is this job?
? I have liquid wrench and Kroil, so will start soaking everything shortly, but is it likely to turn into a rapid downward spiral of add on projects?
For the manifold gasket, currently it has 2 of what looks like the same style Cruiser Outfitters sells and that is working, should I stick with two of those, or go with Remflex?
I do not have to pass smog here (hence the Holley), so I am planning to just pull the flapper and shaft, weld up the hole, and install the Cruiser Outfitters blocking plate. Winter lows here are usually in the teens, so not too crazy cold. If I'm doing the blocking plate, is it worth also welding up the intake, or is that totally unnecessary with the blocking plate?
Sorry for the questions, I got burned the last time I touched a bold on my exhaust so now I am gun shy, and the Goat is my normal DD so minimizing downtime is a factor for me to consider.
Thanks!
Clark
Thanks!
Clark
