Headlight screw
Henderson, NV
I wanna raise my low beams up a little bit. From the picture attached I'm assuming bolt C is the one I need to adjust.
How the hell can I access that screw without having to take out the entire housing? it's very close to the metal mount behind it and just not seeing an obvious solution.
Obviously they are not made to be taken out to adjust you have to adjust them in the vehicle it's not that hard
I'm sure it's not..what are folks using? a tiny wrench? Have you actually adjusted yourself? it's a tight space
I have you need 1/4 rachet set with 8mm socket if I remember correctly its pretty straight forward .
