I have a 2011 LX 570. Headlight are pointed down. How do I raise them? No info in manual.
Mine has 2 each side. I adjust it. I will see if I adjusted the correct ones. Thanks for the info.There are white hex screws on the backs of the headlight assemblies. I believe there are 3 holes, one is for low beam, one for high, one for both.
Don’t use the screws, search the forums
Jefo13 thanks for the info. Most items are posted are for newer 200 series. Mine is a 2011 LX570. So far I think the 8mm screw is the only way I can see to adjust.For 2016+ vehicles after suspension work this is correct. For other years and when addressing imbalances between sides or between high & low the screws are the only way to do it.
