Wanted HDJ80 or 81 Fuel Tank Pickup Assembly and Hard Fuel lines
Stuck between a rock and a hard place
Looking for the hard lines and fuel pickup assembly from a later-model HDJ80, either the 10mm or 12mm versions. Need from the tank to the fuel filter, and then to the fuel pump. Converting from gas to diesel, thus need to upsize my lines. Pickup assembly from a system which had the subtank preferred, as I have that already installed.
Going to be tough to come up with the later 12mm feed version, new from Japan maybe...but shipping not happening. We've parted a dozen or so early HDJ81s so I've probably got what you want in 10mm, but yeah...shipping is a problem on the main line set.
You'll have a problem finding a diesel tank pick up that is specific to subtank because the factory diesel sub tank set up was main to sub tank source switching valves...not tank to tank transfer ala Gas models. I drilled and tapped my diesel tank pickup top plate for a 1/8 NPT barb elbow to facilitate the sub tank to main tank transfer.
HTH
Thanks Sheldon, that is what I thought. Dave can get the 12mm version for around $50. I will likely do as you did, adding a barb to the diesel pickup assembly for the sub tank to main tank transfer (ala Gasser setup), and have a custom larger fuel line plumbed from the tank to the fuel filter in the engine compartment.
