Wanted HDJ80 HF1A Part time Tcase
Cave Creek
  1. 80 Series
Massachusetts United States
Hello fellow Mudders!
Looking for a replacement HF1A transfer case for my 1995 HDJ80. In a perfect world would like to find a Tcase with low mileage, and if possible maybe a mechanical 4H as opposed to the 4H button (if that exists). Also, current case has the PTO winch. I’m assuming if I buy one without I can just swap out the block off cover and minimal internals? Located in MA.
Thanks!
Amayama has 36120-60351 for a little over $1400.
I have transfer case taken off from a GRJ7 series, igs a facotry part time, would that work?
Do you know what engine/trans it has in it? If it has any of the H15X transmissions then it should definitely work. Also, do you have the 4H button or is your 4Hi manual? The case I have now is electronically actuated, so I have to press the 4Hi button.
Its from a GRJ7, so it comes from behind an 1GR v6 engine, which afaik have the h150f box, dont have the car but it has not electric actuator on it
Frank at Land Cruiser Heaven had some electrically actuated HF1A’s in the past.
You can mix and max some case parts between HF1A manual, and HF1A electrically actuated…
