- Joined
- Jul 22, 2012
- Threads
- 584
- Messages
- 16,434
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Thought this would be a good share. Definitely one you haven’t seen before - when driving my FJ62 the starter randomly engages and tries to crank the engine, and stays on after shutting the engine down and pulling the key out. When it does this, both the turn signal arrows on the dash illuminate and stay liiuminated while the starter is cranking but only when the starter comes on it’s own (Hint 1).
While reinstalling the column clamshell and ignition switch after testing it (it tested fine) I bumped the hazard light switch which to my surprise engaged the starter. (Big hint 2)
Ok, pull the whole dash and AC and expose the main body harness. While proding around I bumped the two wires that go to the brake light switch on the pedal (for whatever reason I replaced the Toyota connector on the main harness with two spade connectors years ago, don’t really remember why). This also engaged the starter. (Hint 3) I assume using brake pedal would also cause this since you essentially bridging those wires when using that switch.
Pulling the STOP and HAZ fuses stops the problem from happening when the switches are pressed, however the starter still comes in randomly when driving.
I believe the starter solenoid trigger wire is getting power from both the power wires to the brake and hazard lights.
That’s where I’m at now. I am poking around the dash harness looking for some burned or chaffed wires. I will find them, I would like to avoid the shortcut of just remaking those circuits. I will share my findings!
