I am doing a frame off restomod on my 77 FJ40. I wanted to use some alloy wheels and anytime I can use Toyota parts, I am a happy camper. I picked up a set of 4 take off wheels that came off of an 07 FJ Cruiser with the hopes that they would fit my 40 and if not I would just sell them later. They were only $150 so I pulled the trigger. Last week, I lifted up one corner and did a trial fit. To my surprise, the wheel slid right into place
. I installed the factory FJC lug nuts and turned the rim to make sure it was true. The size of the 17" wheel allows plenty of room to clear the caliper and plenty of room for the outer tie rod end too. I will just run the front wheels w/o the center caps and use the caps on the rears since they don't have a hub sticking through on that end. If you get some of these wheels, make sure you get or aquire the factory lug nuts as thay are not a tapered seat nut like on the typical FJ40 wheel, they are a collared type like used on newer Toyota's. I will probably leave them silver but I was thinking about having them powder coated white to match my top and front grill when the rig is done.
