It is a pretty good setup, although the ride isn't as good as it was when the LX was "new" (I bought it at two years old).Sounds like a perfect set up. What coils do you use? Any specs re load carrying, thickness, length, etc, compared to the original coils?
I had ARB replace the standard rear springs with OME 862's when I had all the extra weight added. At the time (2003) I didn't know all that much about the AHC, but I knew that I needed to support the extra weight at the rear. I asked ARB about cranking the TBs at the time and they said that they hadn't touched them, and implied it wasn't needed. Wrong! Anyway, the OME 862 springs have the same free length as the original springs, which was what I wanted because I didn't want a lift. I'm sure you can find the specifications for 862's on the web somewhere.
As per this post here I would probably consider air bags to support the extra weight if I did it all again, but at the time air bag technology just wasn't good enough, or available locally, and I couldn't find a suitable solution. I would probably still use rear springs stiffer than the originals, but not as stiff as the 862's.
The front Actuator Spheres are pre-charged to 450 psi, and the AHC pressure at Normal height is 500 psi, as compared to the standard FSM value of 825 psi.
The rear Actuator Spheres are pre-charged to 500 psi, and the AHC pressure at Normal height is 550 psi, as compared to the standard FSM value of 683 to 839 psi.
Those values are with both fuel tanks full: 96 Litres standard and 182 litre Long Ranger. I haven't worked out what the extra carrying capacity is due to lowering the normal working pressure, but as you can see I have picked up about 300 psi front and rear to carry extra load over the standard values.
I haven't changed any of the dampening valves in the Actuators (I wouldn't want to do that), but I run the damping on the Normal setting around town when unloaded, and stiffen it up when loaded and on mountain trails. This works fine.
The front suspension is a little "eager" (bouncy) with the above settings when the LX is unloaded, so I am considering backing off the TBs by one turn, which is equivalent to adding about 45 psi to the AHC pressure. That would still work fine, since the weight on the front doesn't increase as much as the rear when I load the LX up.
With this setup, the LX will still lower down to the Low postiion (although AHC pressure is near zero then), and will raise to the High position, so I don't lose anything there.
