Harrop e-locker
los angeles
I Google but could not find how to disassemble 8-inch e-locker, I'm asking about the locker itself not the ring and pinion or third member. TIA
So I asked Zuk, so grateful for the information I received from Zuk. Told me to remove carrier bearing on the electric side, then remove back stop washer for carrier bearing. Remove spring loaded c-clip, then you'll be able to remove the coil and other components. The reason I wanted to remove the coil was this third member ran with out oil and destroyed the ring and pinion. Fine metal particles have gotten spread everywhere. Need to clean before reassembly.
