Hard top repair
SW Colorado
I have pulled the rain gutter drip rail from the fiberglass dome. Repaired some holes a PO put in, former roof rack? Started to repair the edges of the fiberglass but I'm rethinking that. It has a lot of old resin that was used to bond the dome to the drip rail.
After examining the edge I've concluded that it was bonded to the drip rail then riveted. The factory put an open weave fabric in the joint to space it so the adhesive resin doesn't get squeezed out.
When restoring, what are people using as an adhesive or sealant between the fiberglass and the drip rail? Are you removing all the old resin down to the fiberglass?
A few write-ups on here about the adhesion of the top to the drip rail. In the few that I have removed, I saw nothing between the top and rail. PO's have tried to slow down the water by applying something to the outside of the drip rail to shed the water off. The flexing of the top usually let the water find a way in and started the rust thing. When I did mine a few years back, my body shop person had a roll of black double stick, looked like what you would put between panels. I rolled it around the edge, put the top on and pounded the rivets. It smashed between the fiberglass and gutter and created a little rolled area. Painted after that and moved on. If you press on it with your fingernail, it will give a little, but seems to holding up.
Others will chime in on products that have been used.
From what I have seen and heard on here, it doesn't look like Mr. Toyota did a lot of sealing in that area.
Shane
I used 3m seam sealer between the two pieces then riveted it together and then seam sealed the top seam all the way around.
Thanks, the seam sealant sounds to be a good method.
I've disassembled two tops and both were identical. There's a layer of fabric, like carpet backing, in what appears to be polyester resin thats between/around the edge of the fiberglass. Remove it completely or fill and sand?
I should have added that the factory resin around the edge was cracked and the integrity was severely compromised. A good percentage is gone. Which is why I asked if I should keep going and remove it all or, at this point, fill.
Mine also (72) had some kind of fabric between the cap and the gutter.
I am trying to decide which way is the best way to seal the cap back to the rain gutter. What is the method others have used? Pro's and con's.
1- apply a sealer to the rain gutter then set the cap on, rivet it together, then use a self leveling seam sealer to partially fill in the gutter and cover the rivets
2- Use a strip of butyl rubber caulk between the gutter and cap, rivet together, and then the self leveling seam sealant after attaching the cap.
3- Rivet the cap to the rain gutter together dry and then just use the self leveling sealant in the gutter after.
4- other options?
Mine also (71 model) had like a hessian material which was glued to the fiberglass top. It appeared to be original type of material.
No not yet mate still in pieces
I've used 3M auto body sealant on a couple and I think it is by far the best sealant you can use. I'm a big fan of 3M products in general and this is a good one.
Pete
Pete
Did you put it in between the gutter and the cap or just on top?
Sent from my iPhone
I didn't remove the cap just cleaned under the edge of it with a steel putty knife and applied the sealant into this small gap and on top of it.
Sikaflex between fiberglass cap and drip rail. Then 3M Fast N Firm seam sealer for the drip rail rain gutter.
Search my posts for a complete write up including rivets and rivet tool.
And using cleco tools to position the dome correctly in the drip rail and let the sikaflex set up helps tremendously.
Thank you, that's the kind of answer I was looking for. I will look up your write up, I hadn't seen it in my previous searches.
I used Sikaflex 291-LOT. It's a marine adhesive good for below the waterline, so good enough for a roof. It has an hour working time so you can get things buttoned up before it sets.
There's a post from 9/08/09 where I posted the below info. Search using the term "Sikaflex" and you'll find an entire thread with other approaches to hardtop restoration.
Since I'm getting a lot of IMs about how I did it, I'll capture it here again but I think I posted it somewhere else too. Don't get in a hurry as this process took me several weekends (b/c of time needed for paint, seam sealer, adhesive, etc. to cure)
Here is what I did, step by step and you don't need any fancy expensive tools for the job...but you do need to purchase a couple of special inexpensive tools to make the job much easier.
Rivet setting tool:
C.S. Osborne Model Rivet Setter(USA)
Rivets (1/8" x 3/8" flat head):
McMaster-Carr
Also get a bunch (100+) of round 1/8" rivet washers in aluminum to use with these rivets (can get at any hardware store).
Other Materials:
- 3M Seam Sealer (2 tubes from Cool Cruisers of Texas)
- Sikaflex (1 tube of white, waterproof, and long cure set/up type formula)
- Optional: body filler, fiberglass repair kit, 3M Heavy Duty Repair Filler (all this depends on the condition of your fiberglass roof cap)
Tools:
- sledge hammer
- flat steel plate or marble/cement (to use to brace the rivets when you strike them with hammer)
- "clecos" (at least 30+...I used many more...get the 1/8" size)
- cleco pliers
Picture of Cleco Pliers and Clecos
Separate the fiberglass cap from the rain gutter by shearing or sanding the rivet heads off the underside of the drip rail. If the winshield header is loose, now is the time to remove it. Clean out all of the old seam sealer from the drip rail and sand or media blast the drip rail and the winshield header. Remove headliner from underside of roof cap and lightly sand old headliner glue from roof cap.
Replace any welded nuts that have stripped threads or rusted away (can either tack weld new nuts or drill out old nut and simply place a new nut on top of the old one). Repair any rusted sections of the drip rail metal.
Paint drip rail with good rust preventative paint like POR-15 or Rust Bullet. Try not to paint down inside the welded nuts on the drip rail or else you will have to clean the threads with a proper size tap. Also paint the winshield header with rust preventative paint.
The fiberglass top should be checked for holes or cracks and repaired with appropriate fiberglass repair materials. Especially look at the holes that attach the roof cap to the drip rail and repair as necessary (3M High Strength Repair Filler is excellent for this as it dries ultra hard and strong). Light skim coats of body filler can be used for deep scratches on either side of the roof cap. Do not paint roof cap yet!
To re-attach roof cap to rain gutter, place rain gutter and fiberglass roof cap on smooth garage floor (unless you have a huge heavy duty table or countertop). Place a bead of Sikaflex (marine adhesive...get the waterproof one with a longer cure time) around the perimeter of the roof cap and set roof cap inside of drip rail. Use a bunch of "clecos" to secure the roof cap to drip rail or a bunch of other type of "C" clamps to pull the roofcap and gutter together while the Sikaflex cures. If you are not using clecos, clean out the rivet holes to minimize the amount of adhesive that dries in the rivet holes. Let Sikaflex completely cure for a few days and then clean out each and every rivet hole with a 1/8" drill bit.
To install rivets, insert the rivet up from the bottom / underside the rain gutter and through the fiberglass top, place aluminum 1/8" washer on rivet shaft letting the washer lay in the rain gutter area. Brace the rivet from the underside of the rain gutter with a thick piece of steel or other very hard block of marble/granite/cement. Place rivet tool on top side of rivet and strike with a sledge hammer until the rivet shaft flattens and secures itself against the washer. Be careful and don't strike the rivet too many times after it flattens against the washer...don't break the fiberglass! Repeat this process all the way around the perimeter of the top.
Once all rivets are set use 3M Seam Sealer (the stuff that Cool Cruisers of Texas sells...you will need 2 tubes). Smooth the seam sealer with your finger to re-shape the rain gutter area. Each rivet/washer combo should now be invisible and covered with seam sealer. Let the seam sealer dry for a few days and lightly sand it smooth.
Reattach winshield header if removed earlier...again using Sikaflex and clecos to clamp to hardtop. Make sure you get the angle of the winshield header correct or you won't be able to properly bolt the header to the winshield. I'd recommend placing the roof cap / drip rail combo back on the truck and bolt in place to get the angle on the header exactly right. To secure the header panel, I tried using rivets, but was unsuccessful in attaching them b/c of the location of the mounting points, so I used very short rounded stainless button head bolts with a slightly larger diameter stainless washer on the topside and another stainless washer with flat nylock nut on the underside (use some seam sealer to avoid leaks around the bolts/washer area).
You have successfully restored the drip rail & roof cap! Now you are ready to paint the entire roof cap / drip rail (Cygnus White please!!!).
Hope this helps!
Sent from my iPhone
I nailed 2 4x8 1/2 inch plywood then set the old top with rail on the plywood and took a pencil and traced the out side edge of the rain gutter. This gave me a template for welding the rain gutter together. I gound the edge flat that touches the top smooth. Then i drilled out the rivets. Then set the fiberglass top on the rail and driled holes for rivets in oposite corners. I put seam sealer down then riveting the four holes then i went to opposite corners drilling abd riveting. I got the the rain gutter and rivets from cool cruisers. After riveting i put seam sealer between the edge if the fiberglass and rain gutter. Good luck That was in a 74fj40. I still have to do my 76fj40.
