sleeoffroad said:
Exactly how did he determine this? Was the run-out out of spec? Is it possible that the mating surfaces were not 100% clean when they were bolted on and now he has "trued" them to the wheel hub?
Also, how does this gel with the fact that you mentioned it did not do it before he bumper and suspension install.
I don't see how a distorted rotor is going to cause the vibrations you mentioned in the other thread. If it was that bad, would you not have felt a brake pulsation when you applied the brakes? Also, it if was not true, would the vibration not have been there right after the rotors were done?
Just wondering here. Was there any discoloration on the rotors? Are your calipers releasing properly?
What CV axles are you running?
How did he determine it? Test driving, measuring with appropriate tools, etc. Rotors were turned on vehicle, not disassembled.
I've used this mech for ten years with four diff vehicles. While anyone can have a bad day and make mistakes I've never had issues with them, ever.
It does but doesn't gel. I now think it may have been a different problem. As mentioned previously, I won't know for 100% that the prob I experienced before is resolved until I test under the same conditions; under load, terrain/incline, etc. I would agree, the other vibration was almost violent at times so unlike a rotor.
That said I was also feeling an odd sensation when banking. Not a pulsation per se. I don't know if the rotors were discolored. No problems with calipers releasing.
I've also lowered the torsion bars as per sound advice from Spresso. Thought was that 9 out of 10 100 series don't have problems with pinion angles when "lifted". Mine, like Spresso's, may be the 1 out of 10 that do.
CV's are Oem with roughly 5 or 6k on them.
What I think may have happened is the added weight along with the t bars being tweak may have shined a light on items that weren't an issue with the stock set up.
This issue wouldn't stop me from buying PowerStop again and will do the rears with them when budget allows. Will have them check for "true" before they're installed though as well as any rotors installed on my wife's Volvo.
Again I believe I have it misfortune of having two problems. Will road test extensively this weekend.
