Howdy! Got a brake problem on a HJ-47. I replaced a cracked brake line (front brake circuit, hard line from union on frame to union on front axle). I've bled the brakes and bled the brakes and bled the brakes. There's still air getting into the system. The line I replaced is good, no leaks at the unions. No leaks at the slave cylinders. I noticed a very small seep on the -rear- circuit at the master cylinder. However, when I bleed the left front brake it takes about three presses of the pedal to get fluid. Anyone have any thoughts? I'm stumped, other than stopping the seep at the master cylinder.
