GX470 prospeed roof rack!
prospeed
Supporting Vendor
California
You’re looking at the lowest profile and lightest roof rack for the 03-09 Lexus GX470
3-4 week lead time once GB is completed.
Price is $795 retail is $895 shipping is
GB will end Feb 5th at midnight.
To order use coupon code “GXGB2” at prospeedpower
Features:
  • low profile, light weight and aerodynamic design
  • 6061 1/4” Aluminum side rails for strength and weight reduction
  • 2x1” extruded t-slot cross bar to handle a variety of accessories
  • Designed to be sleek to reduce wind noise
  • fully modular design to handle solar panels, roof top tents and more
  • Black powder coated for corrosion protection
  • Black oxide stainless steel hardware for corrosion resistance
  • Easy to assemble design
  • Limited lifetime warranty
  • Bolt-in design. No drilling needed.
  • Sunroof remains fully functional.
  • Tested to handle 300lbs dynamic and 600lbs static (RTT, Awning and 3 adults)
  • Designed and made in U.S.A
Overview
When we designed the roof rack we wanted a roof rack that looked good and followed the OEM roof rack lines for that OEM + look. The roof rack had to meet a few key design criteria’s, it had to be able to fit in the garage or most underground parking garages and it had to be strong enough to handle the weight of a RTT with a family on top. We believe we created an awesome roof rack specifically for the GX470. The modular cross bars allows a multitude of accessories to mount or attach to the rack. The roof rack is made from strong 6061 aluminum including the wind deflector and strong steel brackets. We offer a standard wind deflector or a light bar version that is cut out to handle up to a 42” light bar. The hardware we use is corrosion resistant black oxide stainless steel so it can handle the elements. The roof rack also doesn’t interfere with the sunroof and makes next to no additional wind noise due to its sleek aerodynamic design.
@prospeed Do you have an exact height difference vs the factory roof rack? I am pretty much at my garage's limit on height with the OEM rack, and would rather not have to deflate my tires to park in there lol.
Edit - The stock rack and cross bars come up to about 2.75" over the roof at the highest parts when I measured.
It’s pretty much at the oem rack height… I can try and get exact measurements for you
