Supreme Fab Works
Supporting Vendor
Hey IH8MUD fam
We’re Supreme Fab works, and we're stoked to introduce our Toyota Cab Mount Relocation Kit, built to solve common clearance issues and eliminate the frame fatigue caused by poorly designed cab mount kits.
If you’re planning to run 35s or larger tires and need the clearance to match—or if you’ve already dealt with frame cracks from a previously installed poorly designed cab mount relocation kit—this is the kit that does it right the first time, with strength and precision you can count on.
This isn’t your average cab mount kit. Ours was developed using a full 3D frame scan for a perfect fit every time. The oversized backing plate helps reinforce and patch damage caused by underbuilt or improperly installed kits—a common failure point we see far too often.
3D-Scanned Design – No guesswork. Perfect fit every time.
Oversized Backing Plate – Reinforces weak areas and patches frame cracks from failed relocations.
Improved Tire Clearance – Get the space you need to run 35s or larger tires.
Heavy-Duty Construction – Fabricated in-house to take serious abuse.
Multi-Platform Fitment – Compatible with Tacoma, 4Runner, FJ Cruiser, GX470, and GX460.
We’ve seen countless rigs roll through the shop with cracked frames caused by:
Whether you’re:
Left + Right Cab Mount Relocation Brackets
Oversized Frame Plates
Polyurethane Cab Mount Bushings
Install Instructions
Install Instructions:
https://www.supremefabworks.com/post/cab-mount-relocation-install-instructions
We recommend professional installation by a fab shop familiar with cab mount relocation and frame repair.
Available now at: https://www.supremefabworks.com/products/toyota-cab-mount-relocation-kit
Looking to get a Cab Mount Relocation Kit Installed? Contact us for a quote.
NOTE: Although we may reply on here this is not the most repliable way to get a timely respose. Please dont pm on here!
Best way to reach us is by:
-Call/Text at (916) 953-9445
-Filling out the Contact Us Form on our Website
-DM on Instagram @SupremeFabWorks
Built for Strength. Engineered for Fitment.
Key Features:
Why Ours Is Different
We’ve seen countless rigs roll through the shop with cracked frames caused by:- Thin, poorly designed cab mount brackets
- Small backing plates that can’t distribute the load properly, causing stress cracks in the frame
- Improperly Aligned Cab Mounts Causing Clicking or Squeaking Noise
- Laser-cut and cnc bent ¼” steel brackets s
- ¼” oversized frame plates
- Poly bushings that will last a lifetime
Perfect for Off-Road Builds
Whether you’re:- Trimming for larger tires (35s and up)
- Repairing frame cracks from a failed relocation kit
What’s Included:
