Gx470 OEM AC Inverter Broken any suggestions? (7 Viewers)
Burbank, California
I have a 2006 GX and I have been trying to figure out why my ac inverter isn't working. I checked the drivers side fuse, engine compartment fuse and relay. Everything looked good but I swapped them out with known working fuses and relay. My ac button light isn't turning on, however I plugged in a small fan to test if it would still work but no dice. In my research, I did come across "resetting" the ac inverter if the wattage was exceeded, but the instructions didn't make any sense.
When I have more time I'll use the multimeter to trace power. Anyone come across this issue or have any suggestions?
