GX470 fog light wiring connector pigtail
HXE
Mall Parking Lot
Hopefully this post makes it a little easier for the next guy, there's a lot of wrong information on what this connector is and what you need to "plug and play" into the factory fog light harness.
Recently I wanted to replace my original fog light housings with something that didn't look so crusty. I decided to go with some aftermarket pods and an aftermarket mount. I wanted to plug into the original wiring harness and be able to go back to factory fogs in the future.
I'm going to try to hit all the words that might help someone searching in the future so forgive the verbosity.
Toyota calls the plug Housing, Connector M
part # 90980-11155
But that will only get you the connector best I can tell.
Cross referencing that will find you an expensive Dorman part and a no-name part on Amazon.
If you want to build your own connector you can do that, I believe I found the correct parts from corsa-technic.com
7282-8120-40 - Yazaki | 090II-2P-5 - Corsa Technic | 2-Way Kit - https://www.corsa-technic.com/item.php?item_id=1044
Looks to be
Mfr:OEM Yazaki
Series:090II Sealed Series
OEM P/N:7282-8120-40
Mating Part:090II-2S-5
I took the easy way out, I finally found what I wanted from Ballenger Motorsports in an amazon listing. They call this a 2 Way TS Series Receptacle (Female) Connector Pigtail (link below)
I ended up calling them to discuss the part because Amazon has it listed as a female connector, it's not.
I ended up buying it directory from Ballenger instead of the Amazon listing shipping was fast and their support was great. They will also sell you all the parts to make your own if you want. (Click associated and mating parts on the listing)
2 Way TS Series Receptacle Connector Pigtail
Just wanted to chime in since I did this recently on mine and I sort of documented it in my build thread.
I was able to source the weather pack pins from Amazon to build out the connectors, as well as the tools to crimp them properly.
I guess Belllinger route is less expensive and easier lol.
  • Like
Reactions: HXE
