Walking and spectacting the hard trails will def. be a good way to see what to look forward to. Are little pit bikes alowd at gretchen's? I have a lil PW that sure beats walking....and is just fun to cruise..
Russ' Ridge was the perimeter road and is moderate, can be hard in the wet if you have a bigger rig like an FJC or 80 and care about body damage. The new perimeter (at least on the NW side) is called "Everything Sucks" or trail 8, and is a winch-fest even for the buggies. Don't take a wrong turn
Easy Street is not easy. You can do it with a full bodied rig but only if you don't care about the body. You will need to be heavily modified if you don't want to winch over everything (lockers, 35+). Elm Street is even worse. The other two trails to avoid if you have body panels are the bunghole and the taint.
A lot depends on how wet things are. I was there last weekend and it was fairly dry, so it is a bit easier than normal in general. In the wet, you have to be careful even on the easy trails or you will slide into trees.
Attached is the latest Gretchen's map.
see my above edited message.
I can email you a copy if you would like.
N8 and I plan to come, even though he's being shy about posting. Saturday and Sunday, wheeling both days hopefully.
N8 shy!!!!!!!![]()
i will be there friday![]()
Jeepercreepers? What are YOU driving? : )
I have never been to Gretchen's when it hasn't rained.
Not even trail cuts.....it's always raining.
Has anyone seen it when the sun has been out?
It's been sunny before. Funny thing is it only started raining after you became prez.I have never been to Gretchen's when it hasn't rained.
