OK, I guess it's probably just me being inept, but dang... that grease gun is really a pain. As soon as the darn thing is getting close to thinking it's almost empty it refuses to squirt. Yes, I know, it's the air pockets and all. But then it gets really annoying. I try to take it apart and rearrange the grease to try to empty the darn tube and usually I end up giving up after a few trials, each one having to unscrew the tube off.
I just can't get the tube empty, there is always 2 or 3 golfballs worth of grease left in there... This time I said the heck with it, I just scooped it off and stored it for later.
Then I proceeded to change the tube. First, a struggle to get the old one out cuz it's pretty much cemented in there by grease. After trying to push it off and tearing up the bottom, ended up prying the lip off and pulling it with pliers.
By then there is a fair amount of grease floating around the bench.
Then after I put the new tube in, I figured I may just put the 2 golf balls left over back in the lower end of the tube. Smart, eh? Well, no, cuz now it's too full the plunger can't get back in. When trying to, there is grease starting to squirt out any old way. At what point, when trying to screw the base back on, the plunger rod got unhooked and the spring spoinged sideways, also slathered in grease of course...
After an epic battle with the spring, rod, plunger, tube and all, I was finally victorious. Although covered in grease....
And the darn thing is already 1/2 empty after just a knuckle check.
Which means, it's gonna happen all over again before too long... Aaargh....!
#$%$%$@ thing!
Any and all advice appreciated...!
#$%$%$@ thing!
