Got new free tools =] arc welder and drill press
Orange County
:D well not new but new to me :lol: yes dont think i need a arc. but it was free. So always good to have one laying arould I guess. In fact i never used one be for. And the drill press i wanted for a long time. i hated using a cord less on big things.
DRILL PRESS.
sn 1293887
ARC WELDER
You guys got any infor on this things? try to check for the drill not much out there. Im leaving to school soon so no time to look stuff about them right now
:bang:
:bounce::bounce2::bounce:
Eric
That sure looks like a 3-phase plug on the drill press to me, but I'm not an electrician. Are there 3 "hot" legs on the shut-off switch in that gray box?
Before going thru all the trouble to get it wired up, grab the chuck and see if there is any "slop" in the quill, which is the part that moves it up and down. If it wobbles any at all side-to-side in any direction, then the quill is worn out. I've seen a lot of those older Delta drill presses like that, heavily used and ready for the scrap heap.
Don't know anything about the stuff you got but I do like the word free. It maybe old and a lil outdated but for free it think it might just work.
Sweet deal....
Eric,
You suck! You and your free tools.
Charles
No play at all. Dont really think this thing was beat up so much or seen power in who knows how many years since it was stuff in a stoage room.
I think it did say 3 phase. but not sure havent had much time with 8 am to 9 pm school.
I did take a better pics when i got it home. try to check on friday my day off
charles, You cant have to many tools. mostly when they free :D no im not a free loader. just seem to find people giving stuff to me :bounce: lol
Eric,
Good to meet you at Mark's
Have fun with this stuff and keep it up.
I sold the same drillpress as that for $400 last fall.
-Stumbaugh
Eric,
-Stumbaugh
One hell of a weekend huh? Was get to see you again.
Any tips on this thing? every info you have would help. sinces im need to all of this.
Thanks
Eric
Eric,
Me thinks that the almighty Pinhead is right and that is 3 phase...get another motor for that thing, pretty simple to do. You might be able to get a phase converter as well. I know nothing about 3 phase.
That Miller 200 mig that you have there looks like it has a spot timer built into it. That is what you need for the type of welding we were doing on Gene's truck. You don't "need" the spot timer, but it sure makes it easier and it tends to look nicer too.
Charles if a fan of those old Miller 200's as well.
Stick welders are handy for a few things. You can weld cast iron with them, you can hard surface, they are also great for welding dissimilar metals and dirty metals like farmers often have to when doing repairs . For example, you can weld two different kinds of steel together when doing a repair (hardened steel tooth to the mild steel frame of a land scape rake or plow for example - dozer blade tooth is another example). I found almost zero real use for the one I had and used mig or tig most of the time, but they stick process is here to stay.
No SKP-35 spot panel on the MM200. I have the spot panel, but have not tried it out yet on my MM200 welders.
that drill press looks like a real score! lots of times the old heavy duty machins are way better than anything you can buy now...in our carpentry shop we have a few machines that are from the 60's and they are brutes. enjoy the free tools
charles. the miller hasnt been to good latey. remember how i replaces the liner! well cable still gets jam up and stuff. could it be the whole gun?
Eric,
What mig gun are you using? If you have a real old gun, it might be worth replacing with something newer.
Also, do you have the drive roll lined up? Proper tension?
Charles
Eric,
Charles
whats the dif? mines the one that has to wheels and a springy thingy on top. i get a pic soon:D
well it just keeps on getting better. i love july lol. been on 2 tv shows. gotten to wheel. and so many free things. :bounce::bounce2:
Uncle gave my dad a call last night when i was out. that he had a table made out of stainless steel. really nice and im going to use it as a welding table know. way better then my wood one that gets on fire. its all tigged and its heavy
Eric
Thanks
tweco mig gun model no 2
That would be worth keeping if is not all beat up. Are your drive rolls clean and free from grease and grime?
Nice score on another freebie..
well the rollors are set for the .035 wire thats what I have and its clean. it was working great like 2 days ago.
anyways my uncle just stopped by not to long ago and he brought a converter and makes the 3 phase to single 220 faces. i dont know what he really did i just watched. lol. Just need the plug to hook it up to the wall. it worked tho.
eric
