Gassiper,
How did you make out on the install?
Gassiper,
My wife's LX has a blown speaker, and I want to replace all of them. Does Memphis have speakers that match the OHM rating of the factory speakers?
It’s cheaper to make wood ringsWait, lx models have speaker enclosures in the doors?! I want a pair!
I'm not interested in rings as much as a closed and sealed space to put my speaker in.It’s cheaper to make wood rings
I have a ring of dynamat around the speaker and one behind it, along with bunch of dynamat "tiles" all over the outer and inner door skins. It's better, but I'm told a layer of closed foam is needed between the door metal and door card to insulate and decouple.You then cut a ring of dynamat and/or closed cell foam (yoga mat) the same size as the rings. u put that between the wood rings and it’s sealed once you bolt back in. I wouldn’t steer folks wrong on this one. You’re out 5$ in wood, 10$ or less in a gym mat, and a couple sets of dynamat from Amazon. you can put the extra inside your door.
If you don’t have rings to simulate that plastic bracket you should do that stat. The factory plastics is Easier. but if you’re running aftermarket with deeper and bigger magnet drivers, the wood ring solution is pretty good. I know I threw away my factory speakers but I’ll check when I get home if I have my factory rings and if I do I’ll gladly send em to you for the nominal fee of shipping. I have and lc and would assume door layout is the sameI have a ring of dynamat around the speaker and one behind it, along with bunch of dynamat "tiles" all over the outer and inner door skins. It's better, but I'm told a layer of closed foam is needed between the door metal and door card to insulate and decouple.
I just thought having them in a factory provided box would be the easier route.
I want one now!Can you post pic of the box you are using. My full system will be installed in 2 weeks and have not decided on a final sub yet.
