Looking to find someone who knows what do to with an FJ40 when I need servicing? Any recommendations appreciated. Thanks.
John Smith said:I don't have any shops I can refer you to but the 40 is a pretty simple vehicle to work on. Get a FSM and you will see just how simple.
greytandy said:What is an "FSM"? Field Service Manual? Where do I get one?
Blue77FJ40 said:Factory Service Manual
Some alternatives and where to order reprints from Toyota:
1. Haynes available at any auto parts store or on eBay or autorepairmanuals.biz
2. Order the factory books from Toyota MDC (material distribution center)
Toyota Service Publications
750 West Victoria St.
Compton, CA 90220-5538
1(800) 622-2033
Engine
Chassis & Body
Emissions
3. Subscribe to: http://techinfo.toyota.com
Blue77FJ40 said:Historic means that the vehicle is 25 or more years old and has *not* been modified substantially from its original form.
Street Rod means that the vehicle is 25 or more years old and has been modified substantially from its original form.
Both John and I chose to use Street Rod plates. I figured for whatever reason, that I'd be less hassled with SR plates. Best news is that there is no emission testing. Or any other testing for that matter. In MD, the only safety inspection is when the vehicle is purchased and is a requirement for the registration. Registration is much cheaper too. About $54 vs $154.
You can go to MD MVA site and download the Historic/Street rod pdf file to complete prior to registration.
There are caveats for vehicular use, such as not for daily transport, but if it's not abused, there shouldn't be any problems.
John Smith said:Greytandy, Unless you plan on using the 40 as a daily driver I strongly suggest that you register the truck as a Historic vehicle if you do not plan to highly modify the truck and wheel it.
If you plan to SOA the truck or cut it up from stock form you should register it as a "Street Rod". In Maryland you do not need to inspect the vehicle or even take it for the every other year smog test if you register it as Historic or Street Rod. You simply go to DMV with the title and they hand over tags after you prove insurance.
There are restrictions on how often you can drive the Historic or Street Rod but unless you are daily driving it you should not run into any issues with the law. Both Dan and I have our trucks registered as Street Rods and have had no issues driving around.
Here is a link to FSMs in PDF format. http://www.birfield.com/downloads-cat-1.html
John Smith said:Dan beat me to the reply. Dan correct me if I am wrong but I thought there is no inspection at all for Historic and Street Rods in MD. Sounds crazy I know.
Felix said:That doesn't sound too crazy. In VA, I've never had any kind of inspection on the 40 with historic plates. It would fail, too, because I don't have a working horn or parking brake.
greytandy, don't worry too much about the driving restrictions, as long as you're not daily driving it to work. They're just about the same in VA, and I've never had a problem. The only time I could see it being a problem is if you started driving it to work every day and you passed by the same cop a few times in a row.
As for the other restrictions, here's the info from MVA:
"It can only be used in exhibitions, club activities, parades, tours, occasional transportation and similar uses."
Club activities = meetings, wheeling trips, tech days, etc
occasional transporatation = drives to test repairs, trips for ice cream, cruising for chicks, trips to the beach, anything else
You'll be alright.
nilepoc said:Thanks to this thread, I now have a slow moving slow rusting street rod in my drive way.
cheers to you all.
cheers to you all.
