Good ole P0705 Park Light
Alpharetta GA
Well my 2006 threw a weird wrench at me yesterday. The Park light stayed on all the time while in drive(both lights work fine normally) but the car drove totally fine. The next day the P light started flickering on and off and the locks started cycling. I put it in park at a red light and shut it down for 30 seconds. Upon restart the check engine light/VSC lights both popped up but the P light went out in drive. I checked the code this morning and just the P0705 came up. I read lots of old threads about this problem but none of them really ever came to a conclusion. I have had a very small water leak during hard rains but only the center portion of my pass side front floormat gets just a little wet(about the size of a half dollar normally). I haven't noticed any other moisture anywhere else in the carpet. I cleaned the sunroof drains and it slowed it down a lot but still get the small leak during very hard rains and unfortunately I haven't been in a position to go sit in the car when this happens to see where it's coming in. I did check the fuse block under the pass side of the dash and it doesn't have any signs of corrosion or moisture. Anybody else out there find a resolution to this?? I'm tempted just to clear the code but hate to hide from problems for them just to pop back up at the worst times. TIA!!
Ever figure this cookie out? Same exact issues today. Shoddy windshield replacement but unsure if it's bad enough to leak.
