I've read countless threads on raising the front by adjusting the torsion bars, I hoping this group will confirm or change my thoughts on my plan to get my 01 back to roughly the stock ride height.
My situation is I believe my truck is all stock. I want to leave the rear height alone. Currently i'm seeing a 1" drop left to right on the front. The drivers side being lower. The rear is within a 1/4" which is fine and i'm sure might be level if the front is leveled. If I raise up the drivers front 1" i'll be 2" lower than the rear. If originally there was a 3/4" drop rear to front I'd need to raise the front 1 1/4" to get back to stockish setup, i like the idea of having some cushion in the rear as I will pull a 5x10 trailer often and the rear wont be wayy down compared to the front if i was to make it level front to back..
Would it be best plan to just re index the stock TB's? as it seems 1 1/4" for the passenger side and 2 1/4" for the drivers side seems like a lot and will reduce the down travel or preload on the truck.
I did have the thought i've spending the 1k or so to get the ome kit, new tb's , shocks and diff drop. which may be an option depending on what feedback i get.
Enjoy
Rob
Enjoy
Rob
