Now all i need to do is prime and paint. I decided to go back to rustic green. After i ended up sanding everything i noticed she is almost rust free with the exception of two minor penny size spots.
I used a 7" sander/polishing unit i bought from harbor freight. I used 50grit to removed the "7" layers of paint that were on her. It took me about a total of 12 hours to sand her down. Until i paint it i'll need to patch some drill holes the PO made so i will probably get some clear coat at autozone and put that over it until i get ready to paint. Will i need to resand the clear coat off before i prime her?
I would wipe it down with something to remove the oils, dust, and other contaminates, then spray on a coat of self etching primer. Then, when you are ready to paint, you won't have to remove the primer and the metal won't be flash rusted.
X2.
If you clear coat it you my find you will miss bits in seams and on edges when sanding it back off again, and this could cause your new paint to flake away on the edges allowing in moisture, and we all know what that leads too
