Geolander M/T 's
crappyone said:
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=ORMT
That gives Dry Traction, Wet Traction, Hydro Resistance, Snow Traction, Cornering Stability, Steering Response, Ride Comfort, Noise Comfort, and Tread Wear. It doesn't have Every Tire out there but has ALOT of them. And they are Reviewed and Rated by Us Consumers. Not Sure if you already knew about the site, but figured I'd throw it up there.
I like the Tire Rack and the fact that it has user reviews...BUT, it is my understanding that they are owned by Firestone, so you should take everything with a grain of salt.
What just because the Firestone Desty is #1 for M/T tires you think it's rigged or something? lol. Well Firestone tires don't even Rank in other catagories on there. The M/T's are the ONLY one's that have Firestone at #1. So I'm not worried. Go ahead and worry I guess. But it doesn't discourage me.
I'm running with a set of Yoko Geolander M/T's. I have been for the last three years and am just starting my second set. I didn't have any problems with the first set other than them gripping more than I'm comfortable with. Makes the LC lean on hard corners.
I've never compared them to other brands. They work for me and last long enough for me. They do get noisy when they're worn down, but all tires do that and I use the noise as a sign that you have start putting money aside for a new set of tires which will be needed soon.
Kalawang
