...so had the gas leak-dealer replaced the rotted part from the gas tank -started another leak- apparently one of the units that snakes under the passenger rear side fender and connects to the charcoal canister had rotted away. I finally ( after working hours with them!) figured that it is a part that is available and ordered it....so for now they tapped the 4 units ( hoses) that come out of the gas tank that go to the charcoal canister till the ordered part comes in .
the issue that I am concerned with is that as there is no place for the gas to vent out of , not only there will be tremendous pressure building up inside the tank as the gas is used up while driving and possibly 'crush' the tank...? I replaced the gas fuel cap with a one that supposedly 'allows' for air to go in to balance of the volume of gas being used...but this morning when I loosened the gas cap got a tremendous whoosh!!!..so definitely big pressure building inside...should I just park it and wait for the part to come in ( takes a long time up here in Alaska!) or am I safe driving the vehicle without damaging the gas tank ( or any other component)?
