G2 Tundra upper control arm bolt/nut tq spec?
LINUS
Waiting for the Great Pumpkin
PNW - WA
Anybody have access to that ft/# value?
Part of my suspension fix involves new upper arms, and it appears that torque spec wasn’t given in the install paperwork.
-It’s 1 big ~8” bolt / nut from what I can see, I’m not on the online FSM so longshot someone else has been there / done that.
Through bolt 173ftlbs
Ball joint 81ftlbs
Thanks @Jgrauman - that whole post is worth a copy/paste here:
Tie rod end: 51 ft lbs
Top coilover bolts: 33 ft lbs
Bottom coilover bolt: 144 ft lbs
Upper control arm ball joint: 81 ft lbs
Steering knuckle: 81 ft lbs
Sway bar bolt: 89 ft lbs
Top stabilizer bolt: 111 ft lbs
Lower control arm ball joint attachment(2 bolts): 221 ft lbs
Lower ball joint: 123 ft lbs
Control sensor wire A: 10 ft lbs on UCA
Control sensor wire B: 21 ft lbs on spindle
Sway bar brackets bracket (4 bolts): 51 ft lbs
UCA through bolt for Total Chaos UCA: 173 ft lbs
Total Chaos Uniball: 100 ft lbs
Rear leaf spring: 77 ft lbs
Rear Ubolt: 74 ft lbs
Rear shock upper: 21 ft lbs
Rear shock lower: 66 ft lbs
Aluminum wheel: 97 ft lbs
Steel wheel: 154 ft lbs
