FZJ80 Timing Chain Tensioner 13540-66010
San Jose CA
Hi Folks, (re-edited)
1997 40th Anniversary 200k Miles
Early FZ80 (1993 - 1994) engines used a Ratchet Locking timing chain tensioner. This type of tensioner expands with oil pressure and then locks in place (PN: 13540-66010). This part number now subs to 13540-66011 (1993-1997), which is the non locking type.
The locking style chain tensioner helps keeps the timing chain quiet at start up (until the engine builds oil pressure). I do not know this specifically. Just from my research.
On my rig I had two internal oil leaks. The oil flow restrictor plug (the manual calls this an oil orifice) had backed out between the block and cylinder head, and the oil pump O Ring behind the timing cover (timing cover leak below the distributor and above the alternator). The timing cover O Ring was hard and brittle. I could hear the timing chain when the engine sound bounced off freeway sound walls. While I am not rebuilding my motor. I thought my timing chain had stretched or the tensioner had gone bad; hence the loud chain noise. So I replaced the chain, chain guides, crank/cam sprockets and the tensioner. The timing cover had to come off to fix the oil leak. The original timing chain, gears, and tensioner were all in spec (normal). Bummer. I am sure Toyota had a valid reason to eliminate the locking tensioner for the 1FZ motor. What surprised me was the number of Toyota engines still using the locking type chain tensioner (present day). I did not check/test my actual oil pressure. I just liked the idea of having the chain tensioner hold position all the time. Shame on me for second guessing the Toyota engineers... I mean why does the new land cruiser have a full lift hatch door? vs. a split tailgate. To quote another mudder. Maybe they don't prep/cook or make sandwiches with/in their rigs.
After searching other Toyota models, I found PN: 13540-75020 which is a near match dimensionally. The difference being the width of a metal ridge. The diameter is identical The oil hole and tensioner position is the same. The mounting holes and angled flange cutout are the same. I replaced my oil pump gears and bypass spring as well.
Just FYI
Nice find! Have you tried this or are you looking for thoughts?
I plan on using this PN 13540-75020 once I finish getting my rig back together. Feel free to comment.
Seems sound, though I have to wonder why they spec'd the non-locking version as a substitute if this was in production the whole time. I guess it's possible they decided the belt+suspenders approach simply wasn't necessary. There are definitely Toyota engines that put out less oil pressure, so perhaps the 1FZ simply has enough to keep it adequately tensioned, doing the job adequately with a cheaper part. I don't see that as a reason not to try it though!
Just FYI
View attachment 4059483View attachment 4059482
Did you ever end up trying this? Mine has start-up rattle and even when just passing cars I can sometimes here my chain...
The locking tensioner was installed. However, I have not started the engine yet. This will happen in the next few weeks. I can say the locking tensioner install and ratchet release follows the FSM exactly. I also replaced the chain and sprockets. When I measured/spec'd the original chain. It matched the FSM. No chain stretch
Mine has start-up rattle and even when just passing cars I can sometimes here (hear) my chain...
Are you sure it's the timing chain and not "pinging" from the engine (detonation, timing issues)??
Your tensioner may be stuck (sludge/varnish), or the chain may be stretched beyond the ability of the tensioner to take the slack out. Or low oil pressure/flow to the tensioner/chain and/or the timing chain slippers or sprockets could be worn/broken.
Some things to consider:
Ensure the engine/tensioner is not sludged up (remove/inspect/clean the tensioner)
Ensure the PCV system is functioning (so the engine doesn't sludge up)
Consider a non-solvent (gentle) engine flush with a oil/filter change ( ie: LubeGard, Liquimoly, Amsoil)
Switch to a heavier viscosity full synthetic engine oil (compatible with your local air temps)
Use a quality oil filter with a known good anti-drainback valve (Mobil 1 M1301A for example)
Send a used engine oil sample to Blackstone Laboratories for an Engine Oil Analysis (eg: looking for a pattern of high wear metals)
FWIW
