Fzj80 speakers
Texas
Ok so I wanted to keep the orignal speaker grills on the interior. I realize that I may get negative feedback back on what I used for the rear speakers, but it worked. I used 1/2" spacers on the front to pull the speaker magnets away from the window slide, with same size screws but longer. With 5 1/4" speaker from pioneer, then on the rear the same but 4" speakers, and used....here it goes....plastic toilet flanges.
How do they sound?
I only had one door speaker working at the time, all 9 speakers were factory still. But all but one door speaker was blown. These are a game changer for me. With that being said, I did have to go into the settings and change the bass level. Bass was a little heavy for me but i went in and changed the original output settings on my double din. Will need to install an amp also as I had to bypass the factory amp as it kept blowing a 10amp fuse under my engine fuse compartment.
The rear speaker grilles mount to/snap into the OEM black plastic mount. How do you plan to reattach the grilles?
Do the front grilles/door panels fit flush without rattling on the speaker?
A+ for creativity! As long as things clear and it sounds good, then I think you're golden. :)
The rear speaker grilles mount (snap into) the OEM black plastic mount. How do you plan to reattach those?
Yes the front grills fit flush without rattling on the speaker. On the rears one of the speakers and three hole plastic mounts was missing entirely. So i just got rid of that option and the interior was recently redone so I made a l permanent solution and used an adhesive to keep them on the panel. If i had the other original mount then I may have done it differently. These speakers did fit inside the original plastic 3 hole mount that I had just fyi for any curious, but you cant use the way they originally did it as there is a bolt that screws into the back side of the original speakers.
Would these fit?
Finally a thread where the original grills are kept. I may have to buy some of those Pioneers that you used on the back door.
