FZJ80 - Rotary ELocker Switch, ECU, Rear Harness
Boise, Idaho
Rotary switch and eLocker ECU were purchased new from dealer a few years ago and are almost brand new. Rotary switch does have a few small indentations around edge from trying to improperly be removed from dash (not noticible when installed).
Wiring is the factory harness for the REAR ELocker (plugs into locker motor).
Internet prices if purchased new from Toyota today:
1. Rotary Elocker Switch $48.93
2. ELocker ECU $270.76
3. Elocker Rear Wiring Harness (plugs in to electric locker on rear axle)
$120.92
Total: $440.61
$225 shipped anywhere in the lower 48. OFFERS??
PM me at mmuthart@ctcweb.net
Are you sure these items are for FZJ80s? The wiring harness doesn't seem right, my wiring harness has the semi round ABS plug/connector at one end.
Yes. The wiring harness has the two necessary plugs for the rear locker at one end. There are a couple other plugs along the length; perhaps one is for the ABS but I can't verify. I no longer have an ABS equipped 80.
Would you be able to post a close up picture of the rotary switch from the front side and from the back?
Thanks!
Thanks!
Are these good enough?
Working on the second one; I'm running out of picture post space...
Second Pic...
I'll take 'em, you got email at mmuthart@ctcweb.net
*Edit: Whoops, just looked again. What was this harness removed from? Don't see the ABS plug. Got the invoice that you purchased it from that shows a part number?
I did not personally originally purchase these items from the dealer; therefore, no invoice.
BUT, there is decal with part # on the harness, it reads:
82 ?65-60 080 F-3 Does this help?
Verified from Mr. John Hocker:
Toyota Part# is 82165-60080
That is the part # on my harness as stated above.
Thanks for the pics.
I believe the rotary switch will plug right in to a pig tail that I found behind the dash next to the dimmer switch.
I need to figure out if the LX's came with the ECU. I know they came with some of the wiring.
I am pretty sure you wouldn't be willing to split it up would you? If you will I'll take the switch.
I'm almost certain, if your rig didn't have lockers from the factory it doesn't have the ECU just hiding back there (pass side kick panel I believe).
Yeah, rather not split up yet....
Ya it probably doesn't but I'm pretty sure it has some of the wiring harnesses.
Let me know if anyone ends up just needing the ECU or the axle harness and I'll take the switch. The reason I only need the switch is because I might end up doing ARB's if I can't run into some locked 3rds for a decent price and I would like it to look OEM.
$225 Shipped....
Offers?
is it gone?
still have?
SORRY, I should have updated the thread long ago. SOLD.
