FZJ73 Steering box options (1 Viewer)
Santa Fe, NM
Website
www.billstengel.com
Hello!
I am beginning to get my head around dealing with a very sloppy steering box as I pile through Springtime projects. Search hasn’t turned up much in terms of my truck. Part number is 4411060370
On the rebuilt front, powersteering.com says they will rebuild it but with a healthy turnaround, which is fine, but are there any other options out there? Is Redhead a good option for an rebuild?
Are there any options with a core swap to minimize downtime?
While in the power steering zone, is a rebuild of the lines a reasonable solution? I haven’t been able to find part numbers for most of the lines/hoses.
Thanks!
These guys for the gear box rebuild:
Reservoir to pump hose: 44348-60150
Pressure feed hose: 44411-60610
Cooler assy with feed and return hoses: 44420-60430
All available from overseas Toyota sources.
Much appreciated, @OGBeno, as always.
@OGBeno just heard back from Redhead. They said the sector shaft is slightly twisted and there is pitting on the sealing surface and they’re pretty sure it’s not serviceable.
This comes as no surprise to me.
The part diagrams on Souq and ToyoDIY don’t offer a part number for just the shaft. Might you be able to tell me the part number and/or if there is any compatibility with another shaft?
Many thanks.
VIN is FZJ730004220 if that is helpful
