fuel tank pressure- fj40
northern ca.
So I spent 7 years doing a ground up build on a 72 fj40. Me and a buddy installed a 350 with tbi and a man-a-fre 27 gallon fuel cell. I kept having issues with a full tank over pressurizing and pushing past the sending unit. He found a thread somewhere that gave us the idea to drill a small vent hole (-1/8") in the fuel cap. Now if I get on a good incline and near full tank this thing pukes fuel bad out the cap. Anyone encountered these issues?
Replace the cap with one that doesn't have a hole. Tee off the overflow line and run a length of hose to a location (outside the passenger compartment) that will be above the level of the tank when on an incline. Put an breather or small filter on the end.
yep I did the same with smaller diameter vent holes on both my trucks, my 70 series is fine but my 40 series forces fuel out off angle on a full tank. My 70 series used to vacuum the tank causing cavitation problems and the vent hole I drilled in the cap cured that so I did the same to my 40 series that wasn't causing vacuum issues and ended up with the pressurising and overflowing problem. I drilled smaller holes than your 1/8" hole I started with a 1.5mm drill that broke and ended up using a 2mm or 2.5mm drill.
