Fuel tank plumbing
Discussion in '40- & 55-Series Tech' started by kvk2xtreme, Feb 21, 2004.
  1. kvk2xtreme
    kvk2xtreme
    9
    Feb 9, 2004
    I just finished a 350 conversion and I have a couple of questions. Is it necessary to keep the vapor collector (located behind the passenger seat) in my rig? And do I need to hook up the return line? if so, which tube fitting is it? Any advice would be helpful.
    Thanks
  2. tewlman
    tewlman
    343
    8
    Nov 24, 2003
    getting ready to plumb up my sbc conversion and was wondering the same thing. i believe the vapor collector can go, but planned on posting to be sure. whats the word guys?
  3. LCruzombre
    LCruzombre
    41
    Nov 3, 2003
    Well folks I plugged it and my cruiser is running fine. Be advised this is not a technical recommendation but an experience that so far has worked. :D I will look forward to "real" advise from the "all knowing" FJ40 masters who frequent this forum. :p
  4. tewlman
    tewlman
    343
    8
    Nov 24, 2003
    Great, when are those guys supposed to get here :D
  5. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    plug them all, LOL
    no i suggest hooking up the fuel return and fuel feed from the tank to engine compartment. There you can plug the fuel return if not needed, but with any other setup you might need the return, i just switched to a different fuel pump and i need the fuel return now :D . fuel collector crap i would just cap off all of them and make sure that your vent to the outside through the cap is good.
    as far as which fitting is fuel and which is fuel return, stick some fuel in the can blow down both lines the one that blows bubbles is fuel one that just makes airy sounds is return, :flipoff2:
