Hey folks,
Well I am in the process of getting my truck ready for a rear tube removal and rebuild...
I am half way through dropping the fuel tank (81 BJ42 Diesel) so that I can get better access to where I need to cut the rear tube and it is stuck...
I am sure it must be able to drop through the frame and know it would be a tight squeeze but I can't seem to find an orientation that will do the trick... Is it feasible to drop the tank with the body still on the truck? If so does anybody have any advice on how to manipulate to get the think out..
Right now I have everything that can be removed, removed, all hoses are off, the driveshaft is off, parking brake cable removed... The I figured it would come out is by twisiting the drivers side section (deeper portion) rearward so that and the Passenger side forward, and pointing the driveside down kinda wiggle it out on an angle... The main challenge is that I cant seem to tip the tank enough to clear the drivers main frame member because the passengers side of the tank runs out room on the top...
Any suggestions?
Any suggestions?
