Here's the deal. Previously I have had trouble with my 88 mini not starting on cold mornings only. I placed a jumper in Fp and B+ in the diagnostic port and after a minute or so, the fuel pump would get power and the truck would start. Off to work I would go. This worked about 40 or 50 times no problem. Well, this morning, nothing. Ok, pulled my bed, checked wires again to fuel pump. No power. Put in jumper, no power. Removed battery, hooked up direct to fuel pump, fuel pump kicked on. OK, either a relay or short. Removed relays, checked continuity, everything seems ok. Although I have a crappy meter and I can't read ohm values. I spent hours fooling around with the relays, meter, battery and so on. Could not get constant power to fuel pump, but the pump always worked with the battery hardwired to it. Sometimes I would get power with the jumper in, other times nothing.
From this point I went to the parts store, bought wire and hardwired the pump up to a toggle switch. Figured this would solve my problems. Nope, engine won't stay running with the fuel pump on all the time for some reason. Please help. Should I buy a new fuel pump and see what happens? I don't understand why this would work because mine works fine hardwired to the battery. Or is it a relay? I wired the EFI relay to the battery and could hear it click, sounded operational. I also followed all the diagnostic checks for the two relays (efi &cor) in the Haynes manual. I really need this fixed as I can not get to work. Took today off figuring it was just the fuel pump, but now I'm stumped with my truck in pieces in the driveway and no way to get to work. Thanks for any and all suggestions.
