1993 22re w56 single cab 4WD HILUX. 4 burned exhaust valves, piston & bore damage.
Replaced with one of my personal spares, long block consists of: seasoned short block .20 over with mahle flat tops & rotating assy balanced by my local machinist, new aftermarket head complete with stock sized valves & springs + EB 268 cam, rock auto timing cover + water & oil pumps, good used oil pan & valve cover etc. No surprises, nothing special.
Install manifolds & accessories from core, drop in spare. No surprises nothing special.
Prime with fuel, start, set timing. Check for leaks. Cool down. Restart, warm up, check for leaks, check timing. Test operate: finding, low power above 2500 RPM, return to shop. Cool down. Install SST in place of cold start injector. Perform pressure test per FSM.
